SDOF with Spring
Jamildouier
SDOF with Spring
Post by Jamildouier » Wed Jun 04, 2025 6:39 pm
I am currently trying to model a SDOF system. I have already set up the model, but something seems to be wrong with the analysis. There is an issue I don't fully understand and have not been able to resolve.
It appears to be related to the modeling of the spring – specifically the combination of Uniaxial Material and ZeroLength Element.
Would you mind taking a quick look?
Thank you very much in advance for your support.
Best regards,
Screenshot 2025-06-04 203152.png (25.45 KiB) Viewed 2343 times
SDOF + Sring.zip
(100.9 KiB) Downloaded 87 times
Re: SDOF with Spring
Post by STKO Team » Fri Jun 06, 2025 8:11 am
There are some conceptual mistakes in your model (therefore I suggest you watch the introductory webinars about STKO):
  • Your model does not need all those floating vertices and lines, just 3 nodes. Bottom one will be fixed. Bottom and Mid ones will be connected with an interactions (spring with 3 DOFs as per your sketch). Mid and Top one will be connected either with a spring with horizontal stiffness = k, or with a beam element if you want transversal-rotational coupling.
  • You cannot assign a unixial material directly to a zero length. You have to define a physical_property->special_purpose->zeroLenfthMaterial and put there all the uniaxial material you want for the available DOFs
Jamildouier
Post by Jamildouier » Fri Jun 13, 2025 9:49 am
thank you very much
Post by STKO Team » Mon Jun 23, 2025 9:10 am
