Invalid type of elements or number of nodes
KarishmaN
Re: Invalid type of elements or number of nodes
Post by KarishmaN » Thu May 02, 2024 5:40 am
Thank you for your continuous support.
I have changed the model direction. However I still have problem with the analysis. I attached the new model here , please kindly review it at your earliest convenance time. I will greatly appreciate if you could fix the error in this model, since my free version is about to finish soon and if i couldn't model it successfully our department wont buy the commercial version for our research. Thank you very much for your understanding.
Karishma
Masonry Prism4.zip
(751.14 KiB) Downloaded 145 times
Post by STKO Team » Wed May 08, 2024 4:17 pm
There were some issues in your model:
  1. The error you get comes from an incompatibility between the element property (brick = hexahedron) and the mesh type (tetrahedron).
    To mesh your model with hexa elements I had to add some internal cuts:
    merge everything
    and assign proper mesh controls
Here's a fixed version of your file:
PrismTest4.zip
(1.76 MiB) Downloaded 170 times
I also made a finer mesh to capture the damage better and used OpenSeesMP for parallel computing.
Finally I applied an imposed displacement on top (with load control) instead of a force (with disp control) because with the force only, if the damage will be unsymmetric, the prism will rotate.
Here's what I get:
alex.ivan
Post by alex.ivan » Thu Sep 12, 2024 10:52 pm
I also have the same problem with my model.
Could you please help me to detach the problem? I have attached the model.Image
Imagen de WhatsApp 2024-09-12 a las 17.05.40_dc9d103f.jpg (87.16 KiB) Viewed 1014 times
confined.2.rar
(125.83 KiB) Downloaded 91 times
Post by STKO Team » Tue Sep 24, 2024 8:53 am
You are using a Triangular mesh with a quadrilateral element (those are incompatible)
You either use a triangular mesh with a triangular element property (ShellDKGT, ASDShellT3)
or a quadrilateral mesh with a quadrilateral element property (ShellDKGQ, ASDShellQ4)
Syun
Post by Syun » Mon Jan 20, 2025 9:50 am
I also encountered the same problem.
I have checked the element properties that I assigned, it seemed to be right.
As for the geometry, I am not sure if there is something wrong.
Could you please help me to find the mistakes I made?
There are the error screenshot and my model file below.
Thank you very much!
modal analysis.rar
(458.52 KiB) Downloaded 72 times
Post by STKO Team » Mon Feb 03, 2025 10:45 am
Same error!
You are using the ShellMITC4 element on a triangular mesh.
You either make the mesh all-quad, or use the ASDShellT3 element
Syun
Post by Syun » Tue Feb 04, 2025 9:20 am
Thank you very much for your prompt response!
Following your suggestions, I have attempted to adjust the seeds and set the element to rebuild a quad mesh.
However, despite these efforts, the elements still appear as triangular meshes (as shown in Figure 1), and I am unsure how to resolve this issue.
Additionally, I also tried using the ASDShellT3 element with triangular mesh, but I encountered an error when running the analysis (as shown in Figure 2).
I have attached the model file for your reference. I would greatly appreciate your assistance in resolving this matter.
Thank you very much for your time and support. I look forward to your response.
meshing problem.rar
(609.5 KiB) Downloaded 71 times
Post by STKO Team » Wed Feb 05, 2025 9:06 am
An all-quad mesh is guaranteed only if you have 4-sided surfaces (which is not your case).
Use the ASDShellT3, but make sure to use the latest opensees (3.7.0) (we added it recently):
allijkunz
Post by allijkunz » Thu Feb 12, 2026 8:05 pm
I am having the same error with my model, and I was wondering if you could help me find how I can fix it? I am using quadUP elements with a structured quadrilateral mesh to try to model a soil column, and I am not sure if I need to change something about the mesh or if there is some other problem that is causing the error
Here is my model so that you can take a look
FreeField.zip
(223.91 KiB) Downloaded 21 times
Thanks,
Allison
Post by STKO Team » Thu Feb 19, 2026 9:14 am
The file you attached is corrupted and cannot be open
